RE: saito's 220 large bore carb & pump
CG, I ditched the backplate pump and run the big carb with an IronBay regulator, you should see about 200 rpm over the stock carb. The big carb is not the problem regulating the pressure from that stupid backplate pump arrangement is the problem. I use a 20x6 Just Engines Jen-C prop (Biela) same as yours.
