RCU Forums - View Single Post - Dremel, balsa - misc questions!
Old 07-09-2007 | 12:01 AM
747's Avatar
747
Default RE: Dremel, balsa - misc questions!
No it isnt giving out spiral carvings of steel just powdery stuff! I have already drilled 3 holes. Pls advice what lubrication can I use to drill the final hole with ease! Then I wont break any mounts , and will break something else that isnt replaced with steel!
And for the wood issue , can I use 30 min epoxy mix? So I can work slow...What 's the difference between terms 'epoxy' and 'ca'?
Is it that CA doesnt have to mix? I will get some cheap brushes in HD...
Thanks...I am always learning LOL
