RCU Forums - View Single Post - Dremel, balsa - misc questions!
Old 07-09-2007 | 03:39 AM
j.duncker's Avatar
j.duncker
Default RE: Dremel, balsa - misc questions!
RPM chart here http://members.home.nl/b.ollivier/ht...speedchart.htm
Bottom line you should be drilling at about 1500 rpm in steel with 1/8th drill. Dremels Usually run between 5,000 - 25,000 RPM !!
TOO MANY RPM. Use a conventional home DIY drill **slower is better**. Lubrication while usefull is not required. Spot of oil [any] does no harm.
For your engine bay. Buy a can of fuel proofer see http://www2.towerhobbies.com/cgi-bin...?&I=LXAU33&P=0 Apply two or 3 coats to bare wood. [For small areas I often just smear on some epoxy glue .]
