RCU Forums - View Single Post - Dremel, balsa - misc questions!
Old 07-09-2007 | 04:15 AM
piper_chuck's Avatar
piper_chuck
My Feedback: (12)
Default RE: Dremel, balsa - misc questions!
[/quote]
And for the wood issue , can I use 30 min epoxy mix? So I can work slow...What 's the difference between terms 'epoxy' and 'ca'?
Is it that CA doesnt have to mix? I will get some cheap brushes in HD...
Yes, you can use 30 minute epoxy. In fact, this is a better choice than 5 minute since it gives you more working time and it soaks into the wood better than 5 minute. To thin epoxy, do not mix in solvents such as acetone or alcohol. Instead, just apply a little heat to the epoxy with a heat gun, or a hair drier. Heat works better because it reduces the risk of the epoxy not curing properly. Also, studies have shown that using a solvent causes the epoxy to be somewhat porous when it cures.
CA is cyanoacrylate glue. You'll find it called names such as super glue, instant glue, zap, etc. It's a class of glues that cures very quickly. In a pinch, you could use it to fuel proof, but since the fumes are toxic, I prefer to not use it for large areas.
