RE: 4-cycle sizing????
This type of question shows up quite often in the engine forum. The answer is usually dependent on what type of performance you want. If you want something that putt-putts around, a .56 four cycle could be ok. If you're looking for shorter takeoffs, higher speeds, and more vertical, suggestions go to .70 or even higher. Another factor is whether the plane has light or heavy wing loading.
