RCU Forums - View Single Post - JR Programming Question
Old 07-09-2007 | 09:14 AM
Edgar Perez's Avatar
Edgar Perez
My Feedback: (13)
Default RE: JR Programming Question
One recommendation: Mix the throttle to the airbrake so that when you hit full power the airbrake will retract. This helps a lot in case of an abort landing. You can do this with a curve mix.
I also set it up so that the flaps will retract just enough to get more lift than drag.
Edgar
