RCU Forums - View Single Post - paging the Real Dogman
Old 07-09-2007 | 11:13 AM
  #33
The Real Dogman's Avatar
The Real Dogman
Default RE: paging the Real Dogman
dStruct, You might wanna check the springs in your clutch. Mine used to twitch but when I installed new springs that went away, but it sould be the idle is just atouch higher than needed. try idling down just abit and play with the lowspeed to see if that helps
Good Luck
