RE: JetLegend F-16 (1/8) Testflight
I am getting Blow By the piston on the mains and the nose gear. both Ive done everything still a few bubbles comming past the piston and out the other side.
Ive changed the 0-Ring, put tape under the 0-Ring in an attempt to enlargen the diameter. I don't know what else to do. It is slow enough now I could possibly get in a flight.
Anyone have No Leakage??? I am using NAPA Sil-Glyde Lub Compound. Harmless to rubber, 600 deg melt. Water proof. but is super O Lube Better. 3 autoparts stores and not one has it.
