RCU Forums - View Single Post - Disposable epoxy mixing palets
Old 07-09-2007 | 02:24 PM
bkdavy's Avatar
bkdavy
Default RE: Disposable epoxy mixing palets
Try using Waxed Paper. Its cheap for a roll at the grocery store, and one roll will probably last a lifetime. You can choose the size you want for the amount you're mixing, it stays flat so it doesn't heat up, and you can also use it to smooth over microballoon and epoxy fillers.
Brad
