RE: OS or Thunder Tiger?
The rod in the center of the Super Tiger needle valve is for forming an extension. You can solder a short piece of tubing over it as a coupling for a longer extension or you can just take the existing rod and bend it 90 degrees for a lever/position indicator. You also can just saw it off flush with the needle valve body if you don't like it?
