RCU Forums - View Single Post - J600R start problem
Old 07-09-2007 | 07:39 PM
B777
Default RE: J600R start problem
Hi Jeremy,
Powermax can have too much pressure at times but not to the extend that prevents start-up. Once the solenoid is frozen from gas pressure, it may take a bit of time to return to normal stage. Try by-passing the solenoid. Connect the gas direct and go thru the start sequence, slowly turn on the gas while the "G" is showing on the GDT and see if you get any ignition. This will isolate the potential problem with solenoid valve.
You can contact us direct at [email protected]
Regards,
Kraivuth S.
