RE: J600R start problem
So it's unlikely that the pressure from the start gas could cause the solenoid to not operate? Only reason I ask again is that is one of the trouble shooting suggestions in the manual.
Page 26
Problem:
2. No gas light up during start
Cause and Fixes:
Solenoid valve locked closed due to high pressure gas
Avoid pure propane. Use a maximum of 70/30 propane butane gas
I also read on page 8 of the manual to only fill the canister 1/4 to 1/2 full
I'm only mentioning this again because I want to know if that little canister should only be filled no more than 1/2 way, I've never noticed others doing this and I've never done that on my 1300, I just fill it until the powermax stops flowing :P
