RCU Forums - View Single Post - GST. Should I or Not?
Old 07-10-2007 | 09:18 AM
s5lin
Default RE: GST. Should I or Not?
Thanks for posting the pic Dogman. I am still digging that bracket that you made to hold the brake arm. Very trick indeed!!
And Matt if you decide to lock the diff, as Dogman said, you can eliminate one of the brakes, as when the center diff is locked, you can't set the brake bias. The pic Dogman posted is of the fuel tubing replacement I was talking about. Thanks to his picture I hope everything is much clearer to you about what I was trying to say.
Let me know how it goes Matt.
Darkfire,
Get the truck and burn some nitro! There are quite a few excellent CEN supporters here that would be more than willing to help you out if run into some bumps while running your GST.
