RE: DIESEL FUELS, OILS, COMBUSTIBLES AND ADDITIVES
Off topic?
DIESEL FUEL No: ....~~ standard....... NAME: .......... .......,..........ORIGINAL DATE: ........
ORIGINAL REPORTER: .Pe Reivers..LAST EDITOR:..................LAST EDIT:................
FORMULA (in order of decreasing percentage of volume ):
1)-..40..%...ether....
2)-..40...%..Kero....
3)-...20...%..Castor...
4)-....2...%...Truck diesel fuel cetane improver..
The way the mix it was obtained: ..hand mix, ether-to castor, add kero, stir, add cetane booster, stir, store in aluminium flask
1)ENGINE:...MVVS .15 ABC glow conversion...CARBURETOR: .RC.. RUN TIME: .15 minutes .STARTING: ..hand... USER:.me.....
Comments:
four drops prime, engine starts third flip, sometimes tends to bite back, runs with a deep throated bark. Conversion is meant for high rpm operation, where cast iron pistons will be too heavy to balance well.
