Caliber 30 Tail Problems
I have a Futaba 401 Gyro. Ok I went and set the tail back per the instructions. Here is something I noticed, With the rudder servo at 90 degrees to the tail boom, the slider on the tail rotor is centered but there is pitch on the tail rotor which would make it spin in one direction. Correct? If the tail servo is centered should the tail slider be centered with no pitch? It seems as if I have no left control of the rudder. Off the subject, if I need to level out the swashplate at low stick do I do this with subtrim? My swashplate is the slightest bit to the left and a little forward. I know this dosent affect my rudder problem, just another Question. Thanks for the replies. I will not be able to mess with the heli for a few days, I will try it again next weekend. Thanks
Mike
