Back pressure Question
Why couldn't you just put a spring loaded cover on exhaust exit like on a semi truck so when there is not much pressure it alows it to block the exhaust and when you rev it up it opens under pressure of course you would have to experiment with spring tension. maybe?
Darin
someone needs to try this that has a single exhaust tube
