Back pressure Question
Exactly what will the engine do with variable exhaust timing?
It won't run any better for an airplane engine.
Increasing the low end torque is of zero value because the prop load is exponential with rpm. I don't need my engine to idle any lower than it already does - lands fine now, with a Menz prop nearly stops dead in the air when it throttles back.
