RE: Need help leveling and trimming HBK2
Hang in there, yes they seem tail heavy moving the battery up dose help some you can add weight also up front.
Check the two guides that are on the servo arm rod, they cause binding.
I have disconnected my guides and this helped a lot. (They are not need as far as I am concerned they only bind and add weight to the tail) [:'(]
