RCU Forums - View Single Post - GP Super Stearman
Old 07-10-2007 | 09:53 PM
  #943
boxman27
Default RE: GP Super Stearman
Does anyone have detailed pictures of how they intsalled their G26? I've been looking for shots of how the fuel lines were run and the throttle linkage. I ordered the EZ link from Zenoah that replaces the stock cam on the throttle shaft. It was supposed to be "easy" to install. Far from it! I had to cut off the old cam, grind down the new linkage arm, cut the idle adjust portion of the cover casting off just to get it to fit. Now I don't know if I can get clearance for the end of a ball link in the linkage arm! Needless to say it's been frustrating...maybe I've made it harder than it should be. Also, the motor came with a plastic "ram" intake and a different style plastic insulator for installing between the carb and engine block. What is that for?
Any help with illustrations would be great!
Thanks!
