RCU Forums - View Single Post - Great Planes Ultimate Bipe electric
Old 07-11-2007 | 09:42 AM
esherman
Default RE: Great Planes Ultimate Bipe electric
Has anybody tried the Rimfire 35-36-1000 vs. the stock 35-30-950? I have been reading that it seems underpowered with the 35-30-950 and I thought the 35-36-1000 would give plenty more power (500 something watts vs. 200 something watts)(I like to WAY overpower my planes if you can tell! ). My only question is does it fit? The motor in question is 6mm longer than the stock motor, and I don't know if it will fit in the cowl. I used the same motor in my e-flite MFX and all I had to do was use a dremel tool to make the hole in the cowl a little larger and then the prop adapter fit through. Is the procedure the same here? Thanks for any help!
