RCU Forums - View Single Post - Hangar-9 Sopwith Camel Build Thread
Old 07-11-2007 | 04:38 PM
  #222
Tsutomu Mabuchi's Avatar
Tsutomu Mabuchi
Default RE: Hangar-9 Sopwith Camel Build Thread
ORIGINAL: Tsutomu Mabuchi
What I do not like next is the stock linkage of the tail. They are also too tight.
Servos would be strong enough to be able to move them, but I think they would
consume much current also.
I plan to replace them with other suitable linkage for smoother movement, although
it seems to be difficult to do. Only replacement the piano wire with other materials
may be easier. I am looking for a best lod which has less friction.
Have you guys used stock linkage as it was?
Tsutomu Mabuchi
My Bad. The problem of tight push rods were solved. It was simple.
I bent the push rods a bit to fit the tubes then they became very smooth.
Tsutomu Mabuchi
