RE: Building a SPAD Canard
Hi Pilots12
In the photo above your last comment you will see I have a 2 once fuel tank very close to the engine. The main tank is in front of the main wing. Connect muffler pressure to the main tank pressure connection. Connect main tank out to small tank pressure connection. Small tank out connects to needle valve. I have zero fuel problems.
