ORIGINAL: Scott Ellingson
ORIGINAL: dmajchrzak
Forgive me for chiming in so quickly again. But I started to do more looking around at Opti-2 and found this little tidbit in the forums...
" a few things about Opti-2
It sticks to everything in the engine. every thing is coated with a sticky oil
It is drawn to heat, like solder, so the hotter a spot gets the more lubrication it gets.
And it is not synthetic.
Opti-4, for 4 cycles is in every new BMW off the assembly line."
I guess it IS petroleum based... my mistake if I indicated otherwise.. I wonder if this "stickiness" is the cause of some issue?
- Dave
That is the problem with the Opti IMO. It sticks were the heat is and causes rings to stick. It is a black nasty coating. Here is a pic. It is a 46 piston with less than 3 gallons through it. I could not find the one with a little over 3 gallons through it. I had to remove the ring in 3 pieces. Penzoil is great for break-in. Bel-Ray, Mobil 1 2T are good afterwards. Actually the Penzoil is fine all the time. I have a few people using it. One with over 20 gallons and no problems at all. I was sucked into the Opti pit and paid the price.
I have a
Brillelli 46 that has at least 20 gallons run through it, and except for a little brown on top it looks brand-new. All I have ever used in it was Pennzoil 2-Cycle oil at 32:1. My
Venom 45 in my Pitts Monster has
well over 200 flights and the piston is still shiny on the skirt and a little brown on top. Same oil...
You couldn't pay me enough money to switch to another lubricant.
