RCU Forums - View Single Post - Two Engines Vector Thrust Versus One
Old 07-12-2007 | 07:49 AM
saleens7's Avatar
saleens7
Default RE: Two Engines Vector Thrust Versus One
www.offshoreelectrics.com has 4mm solid shafts....
http://www.offshoreelectrics.com/pro...cen-str-shafts
youd want to get a flex coupler to reduce vibrations....
since you will eventually upgrade to a larger motor (700?) a 700 ill have a 5mm shaft, so youll want to have a 5mm to 4mm coupler
http://www.offshoreelectrics.com/products.php?cat=68 (look down the page for the graupner flex couplers.....there is also a 1/8" to 4mm coupler that will work with 1/8" shafts, like the 540 has....
here is a line of threaded 4mm graupner props that will work w/ the 4mm prop shaft...
http://www.offshoreelectrics.com/products.php?cat=60
