RE: Cowl CUtting
IF you have a Dremel or other high speed drill use this fitted with a 1/16th drill bit pushed in so that only the flutes are showing.
This works well as a cutting tool using the side of the drill. [ My engineering teacher is spinning in his grave]
Mark it out with a waterbased pen then cut and tidy up.
