ORIGINAL: camss69
The Fuse with all ready to fly equipment in it minus the canopy, wings, and stab, is balanced at 53cm from the tip of the spinner. The weights on the rest of it should be pretty much the same I would think from plane to plane as long as you have two servos in each wing.
I've started the rudder tray conversion, I recieved my airwild try and hardware kit yesterday, I'm going to try to mount it so that the servos are in the same location, with the tiller arm a little further back in the tail. I'm trying to figure out how to mount the tray in the plane, just some rails mounted to the sides of the fuse and then two rails going across the fuse but how do I hold the rails to the side of the fuse while the epoxy is drying? I don't have a gaint clamp....
Thanks for the info. Can't help with the rails but I am sure you will figure something out.
