RCU Forums - View Single Post - Cowl CUtting
Thread: Cowl CUtting
Old 07-12-2007 | 01:56 PM
rollo
Default RE: Cowl CUtting
Great ideas on creating a template not going to add anything there. When you start cutting though the key is to not push on the cowling with the tool when you are drilling or cutting. Let the tool do the work because too much pressure and you're bound to crunch the fiberglass. This is especially important when you're using a drill bit or other piercing object.
