RE: Byron Mustang w/Original Byron 50--Will it Fly?
THAT IS A GREAT BUY NO MATTER HOW OLD THE KIT IS. EVERYTHING SOUNDS GOOD. THE ONLY THING I WOULD TRY TO CHECK ON IS THE ENG. I THINK IN 1984 THEY WERE USING THE QUAD 35, WHICH DOES NOT HAVE TO MUCH POWER, THEN THEY CAME OUT WITH THE QUAD. 40 THEN THE QUAD 42. I CALLD THE QUAD REP. YEARS AGO AND THERE WAS A WAY THE TELL THEM APART YOU MIGHT WANT TO TRY AND CONTACT SOMEONE. ALSO THE ORIG. LANDING GEAR STRUTS DID NOT HAVE CHROMED SLEVES OVER THE PLASTIC STRUCT. YOU COULD TRY IRON BAY FOR THOSE IF YOURS DO NOT HAVE THEM.ALSO THE ORIG. PISTONS WERE ONLY AIR UP AND GRAVITY AND SPRING DOWN. THESE ARE THINGS IF YOU DO NOT HAVE I WOULD GREATLY TRY TO CHANGE THEM. LET ME KNOW AND MAYBE I CAN HELP. LOKE I SAID IT WAS A GREAT BUY.
THANKS BOB
