Here is the link to download the Panic instruction manual straight from the J Perkins website.
http://www.jperkinsdistribution.co.u...=ARTF%20-%20JP
Also here is a link to a couple of video clip of the lads at Avicraft (they invented the Panic) flying a couple of panic.
http://www.avicraft.co.uk/render.asp...&navIDs=19,181
Keep it light and make sure if you are using the aileron connecting links to make sure you angle the ball cups or you won't get much movement on the ailerons. I found this out the hard way and the ball links kept popping out.
Let us know how you get on.
