RE: Does it seem that Hanger 9 is getting sloppy?
Most of you have a good point. My covering on my tail had creases and was loose. I applied the Iron and heat gun, and it didn't look good at all, then no matter what I did the covering pulled away from the edges... even after I did all I could to keep the heat away from the edges!
Last night I went to LHS and bought a Heat Glove, maybe that will help if I run into that problem again... I can block the heat in certain areas, or hold the covering on the corners.
The last time I ordered a replacement part, the part was perfect. Hmmmm, why couldn't they have done that to begin with? [&:]
Luftwaffe Oberst
Radio Aero Modelers Club
AMA District II
Pulaski, NY
