Just got a Mini-Rodeo buggy. RC18B clone?
I guess this is a clone of the rc18b but I'm not really sure because this is my first hobby grade 1:18. I just ordered a Venom mini modified 370, hoping for a increase in performance and maybe a little less heat. Do you think the stock ESC will handle the fireball? It says its rated at 30amps.
So far I'm going to order:
Associated 10 and 11 tooth pinion for the fireball
Associated blue aluminum drive shaft (to replace the cheap looking plastic stock one.)
Associated RC18t shocks front and rear (blue spring)
the only thing I'm not sure of is the tires and wheels. If I get the trinity hex converter can I run 1/10 scale wheels and tires?
Also thinking about upgrading the diffs with super diffs and replacing the dogbones with the associated blue aluminum ones.
I'm not in the habit of wasting money so any help would be appreciated!
