RCU Forums - View Single Post - Coordinated turn ?
Old 07-14-2007 | 02:50 PM
B.L.E.'s Avatar
B.L.E.
Default RE: Coordinated turn ?
Normal flying, you move the rudder stick in the same direction as the aileron stick. Once the bank angle is established, you return the aileron stick to neutral but you keep using the rudder and elevator together. To end the turn, return rudder to neutral and level the wing with the aileron.
When you are flying inverted, the rudder stick is "backwards" but the aileron is not.
