Composite Bandit throws?
Hi Sung;
This is the setting I use on all my (regular) Bandits, the Super Bandit is still under construction:
Elevators: 1" 1/8 from the root minimum (it will flare better with more)
Rudder: 1"
Flaps: I use the CRC throw gage and i set the flaps at 15 degrees down for take-off and 40 degress down for landing with 1/8" down elevator
Ailerons: with the CRC gage at 10 degrees up and down.
I have two matchboxes - one on the flaps and the other on the elevators. Try to fly the last minute of your timed flight with flaps down, gears down and speed brake down, to see if you need any trimming of the ailerons and to get comfortable with the approch speed.
Good luck...
David S.
