RE: Phenom engine mounting rails
The bottom is hollow under the beams so if you drill through and enlarge the holes on the bottom the nuts will be inside up against the bottom of the rails. I just stuck a piece of trim sheet over the holes to cover them. The engine on mine was still tight when I pulled it off.
