RCU Forums - View Single Post - Avicraft Panic
Old 07-15-2007 | 03:35 AM
  #31
model-flying.com
Default RE: Avicraft Panic
The original Panic had a one piece flap on the top wing that worked with the elevator but many people put on four ailerons to improve the roll rate. I recommend you do the same and either use four servos or make up you your own links as you prefer.
Here is a link to a site where a guy goes through the build of an original Panic.
http://www.plainslane.fsnet.co.uk/project%20panic.htm
This should help you so you should have it flying in a week!!!
