RE: primer help ?
Epoxy does something different when it cures. It is called Amino Blush. The surface must be chemicaly wiped and sanded and wiped again to remove this blush before applying anything over it. You can use primer over epoxy. Just make sure you have a continous even coat of primer before you apply your topcoat or it will shadow.
