Checking crashed engine
Hello,
I have a crashed Saito 91 engine, the crankcase at the back has
a crack.
I am not sure if the crank is bent, there is a little friction when it
is turned and it can do a full turn. The bearing are probably
crushed which could be causing this.
What is the best way to check if the crank is bent ?
I see in the previous post, guys are talking about forcing it back straight. What are the implications ?
Worse case I have to buy crank, bearings, crankcase, carb.
Best cast I would not have to buy the crank.
The bearings are NTN type, would these be the same which are
sold by NTN distributors for auto/machine etc ?
L
