wing loading
Most .40 size planes have a little more wing area than that. The plane should still fly, it will just be a little doggy. Keep your speeds up on landing and don't try and touch the tailwheel first. Also, let her build up speed before trying to lift off of the runway. If you force it off you will probably be picking up the pieces after a tip stall and cartwheel.
