AXE CP Help............Please
Finished putting back together my AXE CP tonight. I installed a DX6, and did a few other upgrades. I went to bench test it, and while I increased the throttle she didn't wan to lift. I held the skids and at full throttle it had no lift. The rotor is spinning in the right direction, and the leading edge of the blades are facing the right way. It looks like the ccpm is not advancing, and the servos are only moving a little bit. I put the whole thing back together the way I took it apart, so I don't think that is the problem. I did take the sevo arms off and set them all to the neutral position. I did this by powering the helli, and turning on the TX and letting them all settle. Thats when I took the servo arms off and put them all to neutral thinking that they were all off a bit. Can someone help I want to get this thing up in the air...Thanks Zen
