Engine Thrust
I would check to see what the plane does when you go from full throttle to idle in flight. If the plane rises immediately after you remove throttle then you have too much down thrust. If the plane dives after you remove throttle then you have too much up thrust. This only applies after the plane has been trimmed for level flight.
