Gp Giles 202 1/4 Scale, Upthrust Problem!!!!
Scott,
No, its an ARF so wing has angles already built in. Color is different on bottom of wing too.
The firewall has right thrust of about 3-4 degrees, which i'm not sure that it needs all that to begin with, as i had to put in a little left rudder trim , because it was turning right, just slightly.
CGis good, because it handles good,and lands like a ***** cat!
Thanks for your input, it is truly appreciated !
