RE: U-CAN-DO 60 + O.S. 120 AX - Will work?
Hey, can somebody send me numbers of aileron control throws. I don't uderstand the manual measurements.
It says ailerons: 2-1/8" [55mm] up and down. But 55mm from where?
So I tried to config the throws based on my experience with others aircraft and set it to 45ยบ up down for ailerons, but the gap between the wing and the aileron become too huge (3mm, at least).
So please, can somebody tell me good ailerons throws for 3D. Please, in degrees, if possible!!
My aileron hinges is not glued yet.
Thank you.
