Gp Giles 202 1/4 Scale, Upthrust Problem!!!!
Rick,
Thanks for the info, i am anxious to see what it is going to do, in that test maneuver. Only problem will be if it pulls in either direction, how do you fix it since stab is now permanent, and wing saddle is not too easy to change because of its thick mass?
Guess i would have to set incidence in stab or ailerons slightly ,and be happy with that. like i said a little earlier,i have the stab and ailerons set a 1/2degree down , and i am going to see if that makes any difference today. Paul
