New flyers - you might be interested in these notes:
http://www.oz********.com/2007/03/le...ers-guide.html
Sicarius, if you don't know how you pulled off the perfect landing then maybe it wasn't you - just good luck perhaps
Steve's points are really important ones - calm conditions, a field that is big enough that you aren't frantically changing direction every 5 seconds and fly higher, not lower.
Oh, and don't glue props back together [:@][:'(]- sure it can sometimes work, but if often doesn't, and the risk of injury to someone from a flying prop blade is just too high to justify the $3 you save yourself.
Cheers,
Oz.
