RE: ircular hovering - HELP!
that might be TBE or toilet bowl effect, and basically the reason that happens is that the lower rotor set is generating more lift than the upper set. This can happen for alot of reasons. You might have a deformed blade and just need to replace them, or you might need to lube your shaft or something.
hopefully that helps you diagnose the problem, and it not just let us know
