RE: aileron flutter
Without much to go on, one thing I try and do is use the outer holes on the control horn and one closer to the output on the servo. You get more torque that way. Sealed gaps are a good practice, as is reinforcing the servo mounting rails. I had trouble with a bipe and solved it with higher torque servos and nothing more, other than to watch my speed on down lines.
