RE: Roll Out Issue- Extra 300s
I know you said that you checked the elevator alignment, but did you check it at just nuetral? Have you check to make sure that the throws on both of the elevators are exactly the same? It is critical that they be exactly the same or they will induce roll as well as pitch. I had a Cap one time that exhibited the same problem and unmatched throws turned out to be the culprit.
Mike
