RCU Forums - View Single Post - Gp Giles 202 1/4 Scale, Upthrust Problem!!!!
Old 04-11-2002 | 04:09 PM
  #36
paulfrmphoenix
My Feedback: (7)
Default Gp Giles 202 1/4 Scale, Upthrust Problem!!!!
AnnMarie,
Again, thank you for your reply. It is great to know that, a large manufacturer, such as GP takes a very real concern about their products. Some companies would not even have the decency to reply.
I guess you could say that my mission is accomplished, as you are now aware that there definitely is some sort of a incidence problem, because of the different posts you are reading, that all say they have to put in down trim in the elevator.
My bird did not have one degree upthrust, it had better than
2-1/2 degrees of up thrust. I am not so sure as to the fact that it is good that i have 1-1/2 deg. down, i am going to put the thrust at the required 1 deg. UP as you suggest. I am also going to check my right thrust, as it looks to be more than the required 2 deg.
After that, i will see if there is any change in level flight, when power is chopped, or added.
I will inform you Via email.
Keep up the good work Ann. I have heard rumors that you new Patty Wagstaff Extra 300 is an AWESOME airplane!!
sincerely, Paul
