RCU Forums - View Single Post - gas fuel with glo plug no ignition
Old 07-18-2007 | 09:26 AM
  #1600
RysiuM's Avatar
RysiuM
Default RE: gas fuel with glo plug no ignition
ORIGINAL: sboxer
I have also found this forum difficult to keep up with.
It is true if anyone tries to read it for the first time. But keep in mind, that this thread is almost 4 years old. It is exactly what you wrote list of experiments, results, failures and successes. If you want to jump to conclusion it can be specified in two sentences. The first (Ralphbf wrote it already):
You need 1 part 10/10 glow fuel and 2 parts gas, and a F glow plug with the adapter.
I can add the second:
And if it does not work for your engine, feel free to experiment and post your results here.
The reason for that is, that there are so many different 2-strokes available, and everyone is a little different as for all parameters, like size, compression, porting, carb size and type etc. There is no golden rule, that will apply to everyone. There is a starting point (First sentence) and open field for improvement for particular brand/size/type/year/model gas engine.
