RCU Forums - View Single Post - engine rpm
Thread: engine rpm
Old 07-18-2007 | 02:34 PM
av8tor1977's Avatar
av8tor1977
Default RE: engine rpm
That's a really strong Ryobi. Is it modified? Are you sure your tach is correct? My 42cc Poulan turns an 18 x 8 at about those rpms...
If your tach is correct, then personally, I would prop it a little heavier to get closer to 7500 static as you say. The prop unloads in the air, and the consequent rpms will be high for a Ryobi.
As far as which prop, that depends on both you, and the airplane. A big slow airplane would like the 20 x 6, as would an airplane used for some 3D flying. A faster, sleeker airplane used more for traditional aerobatics would probably do better with the 18 x 10. You prop the engine according to the airplane, and also according to it's intended use.
Have fun,
AV8TOR
